Sennheiser GSP 300 vs. Razer Kraken Pro V2
to be honest, i wouldnt trust razer.
if you had to go gaming than the gsp 300 or cloud alpha are good choice.
now i just give the random advance of going a non gaming route.
shp9500 with v modo boompro mic. you can power them with anything phone, controller, ps4, and pc. the plus the audio quality will be far beyond any of the headsets you named. thing is its open so that is one thing you need to think about.
still between those two choices? go with the gsp. the cloud alpha is also another good choice.
MERGED QUESTION
Question from jameserang240 : "Razer Kraken Pro V2 vs. HyperX Cloud Stinger"
Which headset you will prefer to use in PUBG and all genre suitable headset for gaming??? Will you give me the cons and the pros of your choosen headset among the two??? Thanks... i dropped out Sennheiser GSP 300 because it is too expensive...
MERGED QUESTION
Question from jameserang240 : "HyperX Cloud Revolver vs. Sennheiser GSP 300"
What do you think is the best for All Genre Games and for quality, they are same multi platform compatible.. and also i play for about 6 straight hours...
Price::
Sennheiser GSP 300 - 99.95$
HyperX Cloud Revolver - 120$
MERGED QUESTION
Question from jameserang240 : "What is the problems of Razer Kraken Pro V2"
I'm going to upgrade my gaming headset and im confused between the Sennheiser GSP 300 and Razer Kraken Pro V2.. will you tell me what is the good choice for gaming??
