Sennheiser Pc 363D using Combinations
impure85
Commendable
Oct 9, 2016
Hello;
I have a sennheiser pc 363d and using it with the usb soundcard it has. Also i have my creative fatality champion sound card and a mixamp pro device, do i need to continue using it with usb soundcard or which combination can i get the best quality in games.
Waiting for your advices
i would suggest experimenting to see which you like.
you can use the 363d with the included usb soundcard, any onboard audio, andy slot soundcard or products like the mixamp and external dac/amp devices.
the usb soundcard provided is generally only as good as low end sound solutions so any mid tier or greater solution may be better but you need to try it out for yourself.
also, virtual surround modes may be different across products so you may like one better than the other. the mixamp would be convenient for volume adjust.
