Separate monitor scaling
MrSniperTrifle
62
Hi community!
I have a 1080p and a 4k monitor in my setup, and I was wondering if there was a way in which my 1080p monitor could be the primary monitor whilst the 4k monitor runs in a correctly scaled mode (and vice versa).
My issue is that that the secondary monitor (in this case the 4k monitor) runs "scaled" (i.e everything is at the correct size), but the overall appearance is blurry (the monitor runs scaled and crisp when it is set as the primary monitor, but then my 1080p monitor runs blurry).
Is there a way to constantly force scaling on separate monitors, which doesn't result in this blurry mishap?
I'd greatly appreciate any help in this matter! :)
Kind regards,
Alex
1) You need WIndows 8.1 or 10
2) You MUST use EXTEND and not clone mode.
If you meet both conditions, you can do per-monitor scaling just fine (I always have it enabled on my SP3, works like a charm)
