[SOLVED] Serious FPS issues with GeForce RTX 3050 Ti ?
Dec 12, 2021
Hi there,
Bit of background, not sure what's relevant - my laptop screen is burst and whilst awaiting a replacement screen, I have hooked my laptop up to an old monitor via HDMI.
Laptop was running fine until yesterday - logged on to WoW to find the graphics very laggy/stuttery and the game was running at 8 FPS.
Tried updating drivers, which caused a black screen. Factory reset the laptop, so I'm running off a clean install. Tried updating graphics drivers via GeForce experience, then tried uninstalling and reinstalling manually.
Game is still running at extremely low FPS and lagging.
Any help in this matter would be greatly appreciated as I'm not sure where to go from here. 🙁
Specs:
ASUS ROG G513QE-HN062T
AMD Ryzen 5 5600H (16MB Cache, 3.3GHz),
8GB DDR4-SDRAM,
512GB SSD
Hi there,
Specs:
AMD Ryzen 5 5600H...
Hi there,
Specs:
8GB DDR4-SDRAM,
512GB SSD
Try this step by step (read till end):
  • Disconnect from internet
  • Uninstall gpu driver DDU (clean and do not restart, for both amd and nvidia gpu).
  • Uninstall all the processors and the chipset in control panel on device manager (should be 16 on yours, also when it asks for restart, click on no) like this:
  • Restart the pc to bios, and update to the latest bios. Then go to bios again after update and load default or optimized settings, then save and exit
  • boot up to windows and install the latest Chipset driver, reboot, and connect to internet.
  • Install the latest nvidia driver.
    *do this all offline until reboot after installing chipset driver, also you may reboot to bios after all of this to set the XMP (and previous settings you did). Download needed files (highlighted word) before doing step 1, do the step by orders.
  • And check windows update (and optional updates) if there is any and install them (except chipset in optional update). Enable hardware accelerated graphics scheduling (available in the latest windows update) in graphics settings and reboot, it should be like this:
Adding another 8gigs of the same configuration (1rx8 or 1rx16, just see which ram you have) will helps with the performance.
