Hi
I had an old P4 2,4(533fsb) socket 478 cpu and bought a 2,8Ghz(used one). I have never upgraded a cpu but still I thought it would be easy.
I didnt do any changes in bios before I upgraded.
The following message came after I took out the old cpu and installed the new one
"Warning! CPU has been changed. or CPU Ratio changed fail
Please re-enter CPU settings in the CMOS setup and remember to save before quit!"
I didnt do anything of that cause I didnt understand. But the cpu worked fine(I thought) after it frozed 10 minutes later. I started the computer and still didnt do anything and the same thing happened. The third time I did some changes in BIOS(cant remember what) cause the BIOS is poor. Can´t do any changes.
Now the cpu is really fucked up and I couldnt keep it working for more than maximum 10 seconds before it frozens and not even ctrl alt del helps.
I changed back the old 2,4 cpu and it works better but still I´m worried
My question is: Do I have to do some bios changes before cpu upgrade? And if I do not. What do I have to do?
The BIOS is Phoenix -Award BIOS v6.00PG Rev A1 and
motherboard SL 85DRV-C
memory: 786 ddr(266)
gpu: gigabyte geforce 6800 silent pipe
