[SOLVED] Serious problems with GTA V Online
zebracl
Commendable
Dec 12, 2016
Hey guys, to make it short I have the following pc specs:
CPU: Intel Core i5 3330 3.0 GHz
RAM: 8 GB 1600 MHz DDR3
GPU: GTX 1060 6GB Strix
HDD 1TB (Not an SSD)
When I run GTA V on individual mode, I can run it easily on the max settings and my average fps are between 50 to 70, but when I play with my friends in online mode, I need to switch everything to the lower settings because the game is going on with a lot of freezes (1 to 5 seconds per freeze) so it's for me unplayable and make me mad, is there any option (software, settings, tips) to run the game more floodly than now?
Thanks in advance!
Assuming you have ruled out your internet/LAN/WIFI connection have task manager open while you play and see what your Memory usage is like. Usually stutters like what you are describing is a RAM issue, you may need to bumb up to 16GB.
I would quickly edit out your curse words as the moderators will ban you for it! Try using high performance power settings. and another 8 mb of ram would do wonders as long as it is same model and speed.
