I've got my 4670K to 4.6 ghz at 1.23v and it's perfectly stable, but the temps eventually sit above 70ºC after only 10 minutes of prime95. Based on my limited knowledge of watercooling and overclocking, those temps are disgustingly high for a custom water loop. The Vcore doesn't seem too high to account for the temperatures (right...?).
I idle at 35ºC
The water loop:
- XSPC Raystorm waterblock
- XSPC AX240 Radiator
- XSPC D5 Photon reservoir + pump
- 1/2 inch tubing
I've got good airflow (side intake fan, two front intake fans, back exhaust fan, top two static pressure fans (Corsair SP120s) for the radiator. The case is a mid tower (i believe this is useless information, but oh well).
I'm using Arctic Silver 5 thermal paste, and i don't think reapplying thermal paste will fix the problem considering how high my temperatures are compared to the small benifit you get from reapplying paste.
I don't know if there's anything i can change in the BIOS, or whether my chip has decided to commit suicide.
Any suggestions are appreciated.
I idle at 35ºC
The water loop:
- 1/2 inch tubing
