Hi,
I'm trying to setup a 2nd router (thick walls) on the other side of house. 1st router (192.168.0.1) has DHCP enabled (starting from 192.168.0.10). Connected LAN to LAN.
I followed the guide I found on this:
https://www.computing.net/howtos/show/add-a-second-router-to-your-lan/243.html
plus have seen this sticky
http://www.tomshardware.co.uk/forum/36406-43-convert-wireless-router-wireless-access-point
The problem is - when I try to assign 192.168.0.2 (or any other 192.168.0.x) to the 2nd router (D-Link) in router mode with DHCP disabled and gateway being IP of the first router, it gives an error message that reads: 'The network id is the same with LAN'. I can only set it to 192.168.0.2 in bridge mode, but I'm not sure that's what makes sense to do as I read it should be router.
Any advice appreciated.
