Setting Defualt monitor for Bios
Zeal514
92
So I have a VGA old Monitor That I am using, with a Nice big HD TV that I use for my main screen. I am running them both through my Video card.
On my bios it has an option to choose which Port I want the bios to run in. The ports are
VGA
Peg1
Peg2
Peg1
Peg2
Peg3
Peg4
I am just afraid to change this setting and not be able to see my bios and really screw myself lol.
Daedalus12
125
Sorry, I couldn't find the info I needed to give you a solid answer. You could always try something out, then if things go sour, reset the BIOS. Since the 550 TI has three display options, I would stick with the first three you have listed.
Zeal514
92
Yea, Imma give it a shot playing around with the settings till I get it. I just been so pre-occupied with getting Windows 8 working (install activation media center etc. etcc. whole thing has been a utter nightmare)
If I disconnect the VGA monitor tho, It boots thru HDMI, so I can probably just check the setting that way, just thought of it few mins ago, hasn't been my main train of thought lol
ty
Zeal514
92
didnt Work. The List I provided was incorrect, It was just off the top of my head its
PCI
Peg 1
Peg 2
Peg 3
Peg 4
Which Peg=PCI Express lol.
My GPU just runs at Standard VGA, If VGA Monitor is plugged in, I dont have a GPU Chipset on my Mobo so I couldnt load to GPU with HD Monitor on, but plugging into the VGA or w/e Port on your mobo with Alt monitor should work, for those reading this post in the future.
