I'm currently using 2 monitors on my desk and have a third sitting there unused, I feel like an idiot for buying it without even checking if I could use it.. and not returning it after finding out that I couldn't. I've decided I'm going to try everything in my power to make all 3 work for my PC.
I'm currently connecting one of them via HDMI and one via DVI, I've tried using the displayport to HDMI adapter that I have and then connecting both the others via DVI but then only two work. Two of my monitors only have DVI ports, one has DVI and HDMI. What can I do to make it work?
What I'm trying to say is:
DVI + DVI + HDMI = No work
DVI + DVI + Displayport to HDMI adapter = No work
(My DP-HDMI isn't 'active', could this be the problem?)
Sorry if this was a load of nonsense, hopefully you can see what I'm trying to say.
I'm using a 7770 on Windows 8.1
(http://www.newegg.ca/Product/Product.aspx?Item=N82E16814150666)
