Hello all,
I am a newbie here.
So I made a purchase of a office desktop (a SFF) from Lenovo- M90S. Should have went with the big tower and would have not had this issue.
The SFF doesn't have a Graphics Card. It is an office pc with i7-10700 and 68 GB of memory and 380W PSU. System Specs
It has a free 3.0 x16 PCIe and 3.0 x4 PCIe expansion slot and I want to add a GPU. However, given the size of the case, I cannot install a proper GPU. Only low profile GPU which is not helpful (the performance is not as good).
The PC is mostly used by significant other for office work. Me on the other hand would like to use it for gaming and thus add a GPU. The GPU doesn't need to run all the time and the gaming/sim racing rig will have a separate monitor altogether, so no issue there either. Also, the GPU will be used maybe 4-5 times a month.
The built in Intel UHD can power the standard monitors for office work.
My idea is this:
i) Use a PCIe Kickstand Kickstand
ii) Connect the PCIe cable to the empty slot in the PC. Use the PCIe Slot/Brack to run the cable.
My main issue is the power supply for the GPU. The 380W PSU that my system has can supply power to GTX 1650 Super without any issue.
But if I want to use a more powerful GPU, I will need more juice. I will need to use another power source. What are my option? Can I buy a 500-800 watt PSU and use the 6 pin and 8 pin connector, just to power up the GPU?
I understand the GPU would have a separate On/Off switch and a separate power supply and not be controlled through the PC's PSU and motherboard. Would this be a workable setup?
Just turn on the PC normally, then turn on the PSU for the GPU and connect the 3rd monitor to the GPU for gaming!
Or does the GPUs power need to be controlled through the motherboard?
I can put the external PSU and the GPU on a RIG, or find a way to put it on the gaming RIG and connect it to the PC when needed?
Any advise or suggestion would be greatly appreciated.
I am a newbie here.
My idea is this:
