i have a new Xcellon DRD501 and 3 new Seagate 2TB drives that I got for free (God Is Good, ALL the Time). I also have a 3TB & 1.5 TB drive that have data on them that I want to place in the Xcellon that I am running under WIN 7 PR w/12 GIGs of RAM. I have a few questions of clarification.
1. I learned (the hard way) that in a RAID setup the drives have to be the same dive or you loose all the data on the larger drive. Is that the same in a JBOD setup?
2. Do you HAVE to setup a RAID when you setup your drives in a box like this?
3. Is a JBOD an actual "raid" or is it TRULY, just a bunch of disc?
4. If it IS a raid, can I raid 3 disc and simply use the housing to safely store the other drives to access the data?
5. Does it matter that my compute has a RAID 0 setup w/4 250GB drives internally?
6. IF I am able to create a JBOD will my system see the individual drives?
I REALLY don't want to deal with trying to move all the data that's on the other drives in the process of creating a raid array of the new & existing drives. I'm doing this in the hopes of getting ride of the sea of USB cables & power adapters connected to my system.
