I have one pc with windows 10 installed in it. i use my additional hard disks in that pc and i directly connect it to my pc using a cat5e cable (i get up to 1Gbps). i want to access the files of my computers (both of them) using my laptop and using the computer near the TV to watch films... (not to remote connect and play, to just open the films in my other computer). Can i do it by just buying a switch (i found a cheap switch "D-LINK 1008a" which is 100Mbps [that is fin for me] ) but i still need the access to my second my pc with 1Gbps cuz i edit 1080p 60fps videos using it (according to what i have seen, 100Mbps isn't enough). what if i do the thing in this picture (directly connect the 2nd pc to my main pc using my cate5e cable and the ports of the mobos [as i do now] and add a 100Mbps network card for both my storage pc and my main pc and hook it up to a switch using some cat5 or cat5e [both of them doesn't have a huge difference in the price in my country ] and also connect to a access point and connect it directly to the pc near the TV, and access all the files in all the pc's using any pc..., so that would be separate ). NOTE : I AM NOT CONNECTING THEMTO INTERNET AND ONLY TO SHARE THE FILES.
DO I NEED A ROUTER, OR CAN I DO IT ONLY USING THE SWITCH (only to share files)
the 1Gbps should be separate from the 100Mbps one which is connected to other devices (because i video edit and sometimes even photo edit using it, so that speed really matters)
can i do the thing in the picture without any problem (even its hard), please guide me or will it cause a problem... please help
when i click on network i see this ( in this pic there is only my main pc with the shared files... [ i have switched off the storage pc but when its switched on i see that pc here too (only the shared folders and drives) ] ) - so, will connecting the computers twice (one using the 1Gbps and other using the 100Mbps which is also connected to other devices) cause a problem?? if i am wrong please guide me!
THANK YOU!
THANK YOU!
