Setting up a system restore(similar to laptops) on desktop
blacknemesist
490
98
18,890
Hi.
So this is what I'd like to do:
I want to install my windows 7,office,photoshop,drivers and some other software on my HDD and then save everything in a separate partition of my disk so that if I want to restore my system to the point where I have everything installed and running I can boot from the disk partitions and get it all done.
Pretty much what laptops do with the system restore function on boot without needing a working OS.
Simply a boot that will get my windows 7,office,photoshop,drivers and some other software installed again.
Laptops have this function and I would like to have it on my desktop.
What software should I use?
Thanks in advance.
You can use the built in Windows backup but I suggest you use a separate disk. If your primary disk has your OS and backup, if you lose it the backup will be worthless.
