Setting up a wireless network
JacLuc12
35
I'm needing to set up a wireless network. The route i want to go is one router with multiple access points placed throughout the building. Also it need to broadcast two SSIDs. The first one will need to be password protected for the business to use. The other SSID will be a guest access. I want to be able to broadcast both of these throughout the whole building so the user can roam seamlessly between access points.
My questions are:
What are some good routers and access points that will work together to meet my needs.
This building would be categorized as a SOHO business so it doesn't need to be expensive.
Also if anybody has a better way of doing this please comment.
^^^ This
Otherwise you are using home routers to cover a large area with way too many SSIDs floating around. or spending thousands of dollars for an enterprise level system.
Here's a link to get you started. You can buy these on Newegg or Amazon.
https://www.ubnt.com/unifi/unifi-ap/
