Setting up an Access Point through wall Ethernet ports
LessTechnical
5
Hi everyone
I am attempting to set up my old wireless router as an access point in my home. I know how to set it up within the web based software, but I have an issue regarding the wiring.
I have bright house Internet and my current modem/router/access point is supplied via the company. I ran an Ethernet cable into a Cat5 jack on my wall, and then connected my old router to the wall via Ethernet in another room. I made sure to check to see that the cables on each wall outlet were connected and punched down, yet I still cannot get any connection through to my old router.
I followed the cables around in my attic and found that they all join up in the box that is on the outside of my
House, I imagine there's a splitter/switch in there... From what I am able to see every cable is properly connected to where they need to go, and my modem/router currently works just fine as it is, yet I can't seem to run Ethernet through the walls. I'd appreciate any help.
EDIT: the router that I'm a attempting to use as an access point has 6 lights: security, wireless, wired, router, modem, and Internet. The only light that appears when it is on is router (and wired when I plug it into my laptop) but is not connecting to the modem. The Ethernet port on my modem does not have a light on to indicate it is being used like with other ports
If it is a Brighthouse box, then I don't know what it is for. It is possible that they have an option to run their input via etherent cable. FIOS has that option. You can come in either via coax or cat5. It is possible that those cables aren't connected to anything ...
If the wires go to a box on the outside of the house, then is sounds like they are configured for phone and not ethernet. Ethernet requires an active switch if more than two wires are connected together. It is possible they are punched down or just RJ45 union connected in that box, but I think you will have to find out what is inside...
Aren't phone cables generally smaller though? My house has three boxes on the outside, the bright house (I assume Internet) one, out of which a phone cable runs over to a second box, which I assume is for the phone, and then the electrical one. So my best bet is probably to call bright house and have them open it up for me? My guess is a fault switch but I'm not sure how likely that is.
You're probably right then. My modem receives its connection through coax. Darn...that's pretty frustrating. Thanks for the help I appreciate it
Since you followed those cables into the attic, you COULD cut them in the attic, terminate them with RJ45s and use a RJ45 pass through to connect the two sides. Do the same (and label the wires going outside and you could restore them if desired.
