Setting up ethernet connection
iNonEntity
206
I recently installed XP on a computer and installed all the drivers via flash drive, but it won't detect the ethernet connection. The motherboard comes with the jack on it, and I have checked the cable, it works on my computer. The steps I took to set up the connection were
  • Control panel
    Network and Internet connections
    Network connections
    Create a new connection
    Connect to the Internet
    Manually
    Broadband connection that is always on
Then it says it's finished, but no connections appear and I still cannot use the net.
check device manager in your network connection there if theres a power management section untick the allow windows to
turn off to save power--its stupid why its ticked by default
Why would this even be an option... Thank you .-.
having it as an option is one thing but ticking it by default is stupid--the amount of times i have solved some ones network issue by unticking that i have lost count of
