Setting up multiple monitors with no display ports and one DVI cable
AmericanPenguin
Commendable
Dec 23, 2016
18
I currently have a ASUS VS248H-P and it only has a DVI, HDMI, and a VGA cable, no display ports. I'm looking into getting the ASUS VG248QE 144hz. Will I need to just connect it to HDMI or get some type of adapter? I only have one GPU and it can support multiple displays.
Nope, DP supports 144hz. the latest hdmi version does too actually, but it depends on if you gpu and monitor support that version. So, vga is basically dead, so it doesn't, dvi-I doesn't, dvi-d DOES, DP DOES, some hdmi do, but most don't. There's a little cheat sheet 😛
