Setting up my sound system on xfi championship pci edition
Well I can tell you what I have done but not sure if you are trying to do the same thing or not. Soundblaster makes a Sound Blaster Digital I/O Module that plugs into the flexi jack and you can use toslink or RCA type spdif connections to your sterio this is as good as it gets as quality goes then you can use your stereo to plug your headphones into... I just did not know if you mean a component system or like normal computer speakers when you say "Speakers"... Also if you have ony one jack to plug into the card always plug into the green jack.
Thent
Thent
