Setting up RAID on an already running machine
wotot2
16
Hello there,
I currently have a 500gb HDD which contains my OS and all of my games from steam. In addition to that I have a 1tb drive I use for media.
I got a really good deal on a pair of 256gb SSD's, and was wondering how to set raid up without deleting any content, if possible. I'd like the 2 ssd's to be in RAID 0, with the 1tb by itself for use with media. I do plan on mirroring the 500gb drive (not nearly full) to the RAID'ed (two drives in RAID) ssd's.
The motherboard I have is a MSI Z87-G45, and while I know it supports raid, from poking around in the UEFI I have no idea how to set it up. So i guess the TL;DR on this post would be, how to set up RAID without destroying any of my current data?
Thanks in advance.
Get the two drives. Just use them as two independent drives.
RAID 0 with SSD's gives no performance benefit, and increases the fail potential.
That does not answer my question; I got a deal on two drives so it's my only choice to get to the size I want. Unless, of course, you are saying I'm better off getting rid of those two drives and buying a bigger one, which I'm not really willing to do.
Okay; that makes more sense. Thank you!
You cannot create a RAID0 volume without wiping all drives involved (ie. the 2 SSD's). Maybe I'm reading incorrectly but the 2 SSD's you plan to put in RAID0 are new... so why are you concerned about wiping any data on them?
Your solution would be putting the 2 SSD's into RAID0 as planned then use something like Clonezilla to clone the 500GB HDD onto the newly created 500GB RAID0 volume.
EDIT:
Or use them separately ^^
Far easier solution assuming your current OS drive has less then 256GB of data on it.
