[SOLVED] Setting up RGB Fans on X570
Apr 5, 2020
7
Hi All,
I have a MSI X570 Gaming Plus MOBO and would like to do add some RGB on it with fans and strips. For this would I need to buy a controller or could I just manually add change the case fans for the RGB ones?
Hi All,
Lots of led connectors on that MB,
2x 4-pin RGB LED connectors (Analog RGB 12v)
2x 3-pin RAINBOW LED connectors (ARGB, 5v )
Thanks Mike.
I am looking at buying 4 Fractal Design Prisma AL-12 fans. 3 for the front and 1 for the back. There seems to be two options the Fractal Design Quiet Fan Prisma AL-12 ARGB and a PWM option. Which one would I want to buy?
