Hi everyone, as title suggests my aim is the following:
I would like to set up a "permanent" if you so will VPN Tunnel between my ISP Router (FritzBox 7590) and my Travel / VPN Router (GL.iNet GL-A1300 /Slate Plus). The reason is I want to surf using my own IP Address that I get from my ISP at home. Now as I understand this is a bit of an issue as I do not have one static IP address, every 48 hours or so I get a new one from my ISP.
But my Fritzbox can generate a DDNS address which I should be able to use to connect to my home network. So far so good. Does anyone know how I can configure the Wireguard on both my Fritzbox and my GL.iNet? Some of the settings I have no idea about.
