Settings for ASrock x299 OC Formula
fkgomez
5
Hello,
I am new to overclocking, but I did purchase the ASrock x299 OC Formula mobo and a delidded 7900x. The recommended stable setting s to run all cores at 4.6GHz is:
  • ■ 1.225V Vcore
    ■ -3 AVX Offset
    ■ -5 AVX512 Offset
Like I said, i am new to this and have no clue how to apply these settings on the ASrock x299 OC Formula motherboard.
I've looked for Vcore but cant find it.
Also not sure where to set the -3 AVX Offset or the -5 AVX512 Offset.
There are some nae setting on this board it's a bit overwhelming. Need a pro to set me straight.
CPU Configuration screen
Voltage Configuration
FIVR Configuration
Thanks
I've looked at the manual. But I cant find Vcore, AVX or AVX512
I see two options that state AVX2 negative offset and AVX3 negative offset but not sure if those are the ones I need to change. Thanks
