Question Setup for recording sound at home on a budget
happymatei
133
Hi,
I would like to start recording some voice overs, songs and such at home.
I would like to know what should i look for?
What mic?
What audio card?
Is an onboard sound card sufficient? Was targeting the 450 Tomahawk motherboard.
Budget is flexibile, but i would look for a mid tier setup.
Thank you!
venzari.
7
For the sound card, I wouldn't worry about spending the money on it yet until you start making money off of your hobby to fund it.
As for the mic you would want to choose between a condensor or a dynamic mic, personally I like the warmer feeling of the condensor and can suggest the Rode NT2A, not exactually entry leave though :)
happymatei
133
Thank you for answering!
I do not plan to make money from this. It is just for my entertainment.
But i would like to be able to record sound ( voice, guitar ) and mix them into songs and such with adequate software.
Is there maybe a cheaper recommended mic other than that? I can not find that one here and it is more expensive than i thought.
Thank you!
