Several bsod problems
jmfields00
14
So my computer keeps shutting down with several different BSOD errors, mostly memory management and tried to write readonly memory. It's working surprisingly well right now, I'm able to write this and listen to Hamilton at the same time. I've just uninstalled Asus Aura, so that might help and I'll try to install the latest BIOS for my motherboard but I'll come back if it happens again. Post suggestions below.
Can you follow option one here
and then do this step below: Small memory dumps - Have Windows Create a Small Memory Dump (Minidump) on BSOD
that creates a file in c windows/minidump
copy that file to documents
upload the copy from documents to a cloud server and share the link here and someone with right software to read them will help you fix it :)
remove Asus AI suite if its installed, it can cause bsoid
What are specs of PC?
Alright, so I deleted a lot of things I downloaded from Asus, and my computer is working so far, but I'll still send the DMP files, assuming I can figure it out. Also, here are my specs, to the best of my ability:
Maximus IX Hero motherboard
NZXT s340 Elite case (probably not important)
Windows 10 64-bit
Corsair Vengeance LPX 8GB (2x4GB) DDR4 DRAM 3000MHz (PC4-24000) C15 Memory Kit - Black
Blue 2TB Desktop Hard Disk Drive - 5400 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD20EZRZ
Intel core i5-7500
EVGA 500 B1, 80+ BRONZE 500W Power Supply
Okay, here's the link https://1drv.ms/f/s!AnP8w5knRLw3hj3H0tKbOxS9QEO9
Okay, so I think the problem is that I had an older version of Windows 10 which was conflicting with Covenant Eyes. It said it couldn't download the Windows 10 update. Also, my PC seems to work fine in the evening, but not around noon. Weird.
