Earlier in the day, my power went out for a brief moment while I was using my PC regularly. When the power came back on and I turned my PC back on, there was an "Updating" symbol where I would usually see the BIOS information. From that point on, there has been severe audio and visual stuttering. I've restarted my PC more than a few times and tried a number of solutions that I saw here but none have worked. The audio and visual stutters do not always happen at the same time after restarting, the audio stutters (pops, clicks) aren't extremely frequent but occur progressively more often until they are roughly 3-5 seconds apart and last for roughly half a second. The video stutters are generally less severe but more frequent.
I've tried to clear my CMOS, done a clean boot of Windows 10, reinstalled all my drivers (I think?), updated my BIOS and disabled TPM in BIOS. I'm extremely, extremely inexperienced with computers and have basically been blindly following whatever advice I've seen in hopes that it might magically solve my problem. I don't know which information is relevant so I'm just going to give you all as much as I have. I've also run LatencyMon despite not knowing a thing about it because I've seen it requested in a couple threads, so I'm hoping that information can help you help me.
System information:
OS Name Microsoft Windows 10 Home
Version 10.0.19045 Build 19045
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-T29F4T8
System Manufacturer Micro-Star International Co., Ltd.
System Model MS-7A95
System Type x64-based PC
System SKU Default string
Processor Intel(R) Core(TM) i7-7800X CPU @ 3.50GHz, 3504 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 1.H0, 9/7/2022
SMBIOS Version 2.8
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Micro-Star International Co., Ltd
BaseBoard Product X299 GAMING PRO CARBON AC (MS-7A95)
BaseBoard Version 1.0
Platform Role Desktop
Secure Boot State Off
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "10.0.19041.2728"
User Name DESKTOP-T29F4T8\Jake
Time Zone Eastern Daylight Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.7 GB
Available Physical Memory 27.5 GB
Total Virtual Memory 36.7 GB
Available Virtual Memory 30.4 GB
Page File Space 5.00 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not Modern Standby, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
LatencyMon Stats:
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs,
clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to
power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:22:35 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-T29F4T8
OS version: Windows 10, 10.0, version 2009, build: 19045 (x64)
Hardware: MS-7A95, Micro-Star International Co., Ltd.
BIOS: 1.H0
CPU: GenuineIntel Intel(R) Core(TM) i7-7800X CPU @ 3.50GHz
Logical processors: 12
Processor groups: 1
Processor group size: 12
RAM: 32444 MB total
CPU SPEED
Reported CPU speed (WMI): 3504 MHz
Reported CPU speed (registry): 3504 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N
Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the
interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a
usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 100796.20
Average measured interrupt to process latency (µs): 21.071987
Highest measured interrupt to DPC latency (µs): 100739.60
Average measured interrupt to DPC latency (µs): 15.776330
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 178.442922
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0.038444
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0.044330
ISR count (execution time <250 µs): 518735
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted
until the DPC has finished execution.
Highest DPC routine execution time (µs): 100749.061644
Driver with highest DPC routine execution time: storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0.231485
Driver with highest DPC total execution time: storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Total time spent in DPCs (%) 0.284637
DPC count (execution time <250 µs): 1487909
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 38
DPC count (execution time 1000-2000 µs): 1
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 552
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The
process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in
dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: nortonsecurity.exe
Total number of hard pagefaults 6748
Hard pagefault count of hardest hit process: 2363
Number of processes hit: 56
PER CPU DATA
CPU 0 Interrupt cycle time (s): 54.877414
CPU 0 ISR highest execution time (µs): 178.442922
CPU 0 ISR total execution time (s): 7.190098
CPU 0 ISR count: 494379
CPU 0 DPC highest execution time (µs): 100733.700913
CPU 0 DPC total execution time (s): 17.041253
CPU 0 DPC count: 1318408
CPU 1 Interrupt cycle time (s): 9.029943
CPU 1 ISR highest execution time (µs): 64.957763
CPU 1 ISR total execution time (s): 0.006787
CPU 1 ISR count: 1702
CPU 1 DPC highest execution time (µs): 315.719749
CPU 1 DPC total execution time (s): 0.040473
CPU 1 DPC count: 6178
CPU 2 Interrupt cycle time (s): 40.673951
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 100711.072489
CPU 2 DPC total execution time (s): 10.980938
CPU 2 DPC count: 103578
CPU 3 Interrupt cycle time (s): 12.143208
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 100680.945205
CPU 3 DPC total execution time (s): 0.211462
CPU 3 DPC count: 3105
CPU 4 Interrupt cycle time (s): 31.085588
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 100723.383562
CPU 4 DPC total execution time (s): 4.148317
CPU 4 DPC count: 19594
CPU 5 Interrupt cycle time (s): 11.562281
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 100649.247717
CPU 5 DPC total execution time (s): 0.242660
CPU 5 DPC count: 2044
CPU 6 Interrupt cycle time (s): 34.394292
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 100670.562785
CPU 6 DPC total execution time (s): 5.456247
CPU 6 DPC count: 14154
CPU 7 Interrupt cycle time (s): 9.844459
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 63.200342
CPU 7 DPC total execution time (s): 0.005864
CPU 7 DPC count: 1327
CPU 8 Interrupt cycle time (s): 29.929774
CPU 8 ISR highest execution time (µs): 0.0
CPU 8 ISR total execution time (s): 0.0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 100705.808219
CPU 8 DPC total execution time (s): 3.160171
CPU 8 DPC count: 8169
CPU 9 Interrupt cycle time (s): 10.576187
CPU 9 ISR highest execution time (µs): 53.889269
CPU 9 ISR total execution time (s): 0.015586
CPU 9 ISR count: 22654
CPU 9 DPC highest execution time (µs): 313.057648
CPU 9 DPC total execution time (s): 0.010606
CPU 9 DPC count: 1277
CPU 10 Interrupt cycle time (s): 36.216469
CPU 10 ISR highest execution time (µs): 0.0
CPU 10 ISR total execution time (s): 0.0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 100749.061644
CPU 10 DPC total execution time (s): 5.003533
CPU 10 DPC count: 9512
CPU 11 Interrupt cycle time (s): 9.778774
CPU 11 ISR highest execution time (µs): 0.0
CPU 11 ISR total execution time (s): 0.0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 77.058219
CPU 11 DPC total execution time (s): 0.009199
CPU 11 DPC count: 1154
The storport, ndis, Nvidia Kernel, and tcpip drivers have the highest execution, each over .5ms. There are an additional 6 driver files which are all over .1ms which are HDAudBus, rspLLL64, CLASSPNP, Wdf01000, dxgkrnl, and ntoskrnl.
Please help. I am so lost.
System information:
SMBIOS Version 2.8
BIOS Mode UEFI
LatencyMon Stats:
CONCLUSION
SYSTEM INFORMATION
BIOS: 1.H0
Processor groups: 1
RAM: 32444 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 2 ISR count: 0
CPU 3 ISR count: 0
CPU 4 ISR count: 0
CPU 5 ISR count: 0
CPU 6 ISR count: 0
CPU 7 ISR count: 0
CPU 8 ISR count: 0
CPU 10 ISR count: 0
CPU 11 ISR count: 0
