Hello all,
I'm looking to replace my dying black macbook with a new SFF desktop. To answer the obvious question, yes, I have thought about replacing it with a mac mini but I've never built a pc myself [aside from in the early 90's with my older brother.] As I remember it, it wasn't very difficult so I thought I'd give it a go.
The plan is a SFF desktop that will last 5 years +/- with minimal upgrades as necessary. I plan on using the IGPU of the 3770k for the time being until I deem it necessary (or feel fancy enough) to run a separate video card.
My questions are; Are the parts listed compatible? (I did my best to check.) The current power draw is 121w according to PCpartpicker. What can I expect it to be after adding a graphics card? (Ballpark?) Is there any need to use additional cooling if I don't plan on OC'ing immediately?
I understand that the specs on this build are pretty overbuilt for my uses, but I figure "Why not?" if I'll be using it for the next 5 years? I plan on using this build for some light gaming but mostly schoolwork, streaming, websurfing, photo editing. Simple stuff really, but clocking in at around $850 thus far it'll rival a top shelf mac mini.
Processor: Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) $329.99
Motherboard: ASUS P8Z77-I Deluxe $184.99
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) $49.99
Graphics Card: IGPU Intel HD Graphics 4000
Hard Drive: SAMSUNG 840 Pro Series MZ-7PD128BW 2.5" 128GB SSD $149.99
Case: Fractal Design Node 304 $89.99
Power Supply: Advice?
Cooling: Necessary?
DVD Burner: SAMSUNG USB 2.0 Slim External DVD Writer $29.99
Your thoughts on this build and constructive criticism are appreciated. Thanks!
Cooling: Necessary?
