Approximate Purchase Date: next 5-10 days
Budget Range: $400-$750
System Usage from Most to Least Important: Gaming, multimedia
Are you buying a monitor: No
Parts to Upgrade: Case, powersupply, ram, CPU cooler, motherboard (reusing GPU, CPU, hard drives)
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg, Amazon
Overclocking: Maybe
SLI or Crossfire: No
Your Monitor Resolution: Dual 23 inch 1920x1080
Additional Comments: I would like this build to be as quiet as possible
And Most Importantly, Why Are You Upgrading: Lack of room for a DT tower. It is also Very noisy for my liking. I am dead set on getting the Silverstone FT03 mini case listed below after seeing one in person.
Does this build seem like everything will work out perfectly? I am re-using my 560ti, i5-2500k, 120gb crucial SSD, and 500gb HDD for now. I will be upgrading to a 660ti in the near future.
http://pcpartpicker.com/p/lu6d
If anyone has any other suggestions I'd love to hear them.
Thanks in advance!
Overclocking: Maybe
Thanks in advance!
