SFX Power Supply Vs. Modular ATX?
Modular power supplies helps in cable management. So you won't have difficulty in deciding the cables you need. and you won't need much And there will be also better airflow for that case.
Hope that helps
Hope that helps
It would be, that is IF the case doesn't come with psu in the first place. If it does come with a psu, then I don't think there is any reason to buy a modular psu. You could still manage cables with the non-modular psu.
Hope that helps
