SFX/SFX-L PSU Help?
MatthewScott
73
I'm building in the NCASE M1 in a month or two and need a SFX/SFX-L PSU. I know Silverstone do a SFX 600W but I've heard it can be quite noisy and I know they do a SFX-L 500w which is quieter and cools a bit better but I'm not sure if it'll be enough as I will be buying the next high end GPU when it comes out and I'm currently running a Gigabyte 970 G1 Gaming with an i7 6700K at stock/4.5ghz OC and will be using a Maximus Impact VIII. Just need to know what the best option would be as it might be a while until Corsair release their 600W SFX PSU and I also haven't heard anything about Silverstone's NEW SFX PSU's since summer.
Any help would be appreciated.
Cheers
Buy the Silverstone 600 watt it will not be loud until you pull the watts from it then your video card and CPU cooler will be louder anyhow.
Thanks for the advice, just wanted some clarity before I start spending
