Shadow of Mordor help
quinn4520
Shadow of Mordor came out a short while ago, and I'm wondering if I can run it on high
PC specs:
GPU: sapphire r9 270 2gb
CPU: AMD fx 6300 @3.3ghz
Full HD monitor
500gb HD
Also: I'm considering running on xbox 360, is that totally non-sensible?
RAM-4gb, I might be able to switch out with 8
Thanks!
Also, I'm considering running on xbox 360, is that non-sensible?
Yes, these specs should easily run the game.
Here are the minimum requirements, you EASILY MEET THEM:
CPU: Intel Core i5-750 or AMD Phenom II X4 965
CPU Speed: Info
RAM: 3 GB
OS: Windows 7 (64-bit only)
Video Card: NVIDIA GeForce GTX 460 or AMD Radeon HD 5850
Sound Card: Yes
Free Disk Space: 25 GB
Here are the reccomended ones:
CPU: Intel Core i7-3770 or AMD FX-8350
CPU Speed: Info
RAM: 8 GB
Video Card: NVIDIA GeForce GTX 660 or AMD Radeon HD 7950
Sound Card: Yes
Free Disk Space: 40 GB
And yes, go with the 8gb RAM, it meets the recommended requirements!
Thanks,
Mrunited12
CPU Speed: Info
RAM: 3 GB
Sound Card: Yes
CPU Speed: Info
RAM: 8 GB
Sound Card: Yes
Thanks,
Mrunited12
