Shadowplay recording problems
Evanshade
when recording with shadowplay or action software it stops after 1:53 every time anyone know why that is?
system specs
Asus sabertooth 990FX R2.0
AMD FX 8320 eight core
32 gig ram
2TB hard drive
geforce gtx 770
windows 7 ultimate
turn off shadow recording and only use manual. it will still cut the video into chunks of 4gb, but they should be 5-20 minutes long instead. if it is still only recording 1.53 seconds, then reinstall shadowplay, and get the most up to date version. another thing is to make sure that the file location is set up for videos, and that say your other software is encoding properly. try playing with the settings (i had the same problem with fraps, so i just stopped using it). also check to see if recording is funky with whatever game in particular you are trying to record
huh?
I work with files up to 30 GB on Windows Vista so I don't see why 7 would be limited to 4 GB
Maybe with fat32 but ...
I doubt he is using that
as i said it is only 1:53 sec and nowhere near 4gb and the same thing happens in action when recording too
