share application with remote pc outside lan
jeranga
8
we have an inventory and accounting application on main server at head office and we have remote locations using the same application remotely through TSPLUS. currently its working perfectly and easy to use and we can share only this application to the remote locations without a total RDP. and it has universal printing facility which can redirect printing to the local printer of the remote user.
my concern is we are planning to add more remote locations and is there any other way to get this done, without affecting the speed. is TSPlus is the best solution for this?
The question is probably best addressed to TSPLUS.
Your server is meeting the current requirements. Hard to tell what increased operational level will trigger a threshold that degrades performance.
If you add more remote locations, more users.... then the server may not be able to keep up.
That holds true for the communication channels involved.
Overall the performance will only be as fast as the slowest link in the networks and devices involved.
You may also have some licensing limitations.
Work with TSPlus first. If you are reaching some limit from their perspective then finding the "best solution" is going to be much more involved.
Thanks for the reply.
