Question Sharkoon TG4 fans work but the rgb lights dont
corne19931802
5
Hi
I recently installed my parts into the case, i have a gigabyte H61M motherboard .
The fans work everything doed except for the fan lights is it because the motherboard does not support the lights or because i plugged something in wrong which is totally possible.
Thank you
Front Panel
3x 120 mm Addressable RGB LED Fans
Rear
1x 120 mm Addressable RGB LED Fan
Addressable RGB LED are +5v and headers for that kind of lighting is found on late model more expensive high end motherboards.
Add-on module:
5V Addressable RGB (RBW) Light Controller Module
https://www.primochill.com/products/bykski-8-4-rgb-fan-controller-b-rbw-c8?variant=14097863278658&cmp_id=1656791230&adg_id=64061230939&kwd=&device=c&gclid=CjwKCAjw8LTmBRBCEiwAbhh-6KbRUSIxHFxxbuOWSiufRmM0lAZekXag98CpdoufQn1fNFzik8qELhoCKeYQAvD_BwE
corne19931802
5
Hi
On the side of the case there is a controller mounted, with 4 cables(i suspect the fan cables)
However there is a cable(gdv which i conected to the system fan port) splitted with a connecter 2space1 cable.
