G
Guest
Guest
Archived from groups: alt.comp.periphs.scanner,comp.periphs.scanner,comp.periphs.scanners (More info?)
Hi
I'm relatively new to slide scanning and now have a Nikon Coolscan III
(LS-30) to mess around with. Now, one thing I noticed was that using the
Nikon Scan software the colour of the initial scan is pretty bad with a lot
of blue tint... it would need a LOT of footering and manipulating to improve
the scan. However, I tried VueScan and it seems to make a good job
colourwise of the initial scan but in both cases the SHARPNESS is not what I
would expect. Yes, there is always a BIT of manual sharpening to be done
with Photoshop or whatever, but the initial scan from my LS-30 doesn't look
too good at all. A friend of mine told me the sort of unsharp mask values
he normally uses with scans but using similar I have no joy. Even
increasing by quite a bit i am not getting great results. I notice this
most easily where the subject has writing (as writing is detailed so more
noticeably blurred).
Perhaps someone else out there in NewsLand has had similar problems or knows
what I am talking about ? I have been scanning at 3200dpi initially. If
someone would like to have a look at a couple of sample scans I can scan to
whatever spec you want .... let me know what size/resolution etc you would
normally scan at and I can scan a couple at the same and email the results
for your comments.
Cheers for any hints or help
Woody
Hi
for your comments.
Woody
