short on cash. will this power supply be enough for a gtx670 and 2500k cpu?
It wouldn't be my first choice for a system like that but it will definitely work just fine. It has an 8-pin and a 6-pin which will cover your 670 no problem and as long as you're not overclocking the processor or GPU too much you should be all set. $29 is cheap but it is 80 plus and haswell compatible so it's not all bad hahaha.
80 plus and haswell compatible? what does that mean?
I was just joking around haha. 80 plus refers to how efficient it is and Haswell compatible just means it will work okay with the new 4th Gen intel processors (4770 for example). Neither of which is really important since you have a 2500K and its only a $30 PSU.
good to know. thanks guys.
oh ok haha
