I have a Sandisk Extreme Pro SSD v2, which I am connecting to my old macbook pro with an included USB-C to USB-A cable. This cable is only 1 foot which I like but is extremely snug at the USB-A end. I am not sure if this is done on purpose to ensure the performance at 10Gbps (or even possibly 20Gbps) or it is a defective cable. At times it connect only at USB 2.0 speeds possibly because it doesn't plug properly (because of extreme snugginess). I am also concerned that it may damage the USB-A port on my computer. I did contact Sandisk and they refused to help in any way. I have another USB-C to USB-A cable rated 10Gbps (Belkin) which plugs fine, but it is a bit too long and too stiff to confortably carry around. I want to find another short cable around 1 foot or so. But here is the problem: there are plenty of those for charging and very few that support even 5Gbps and mostly from some unknown (to me) brands except AmazonBasic USB 3.2 Gen 2 one. So I was wondering if anyone here could recommend a quality short (1foot or so) USB-C to USB-A cable rated 10Gbps (or even 5Gbps). Thank you for any input!
