i know it might sound dumb but I've just built a PC using a Lian Li Dan A3 Case and an m-ATX motherboard. The 24-pin motherboard cable only needs to be very short approximately 17cm as measured with a tape measure in a straight line. Can I be pointed towards somewhere with compatible cables / a way to find out if the cables i am buying will be compatible or not?
thanks in advance
thanks in advance
