Im building an SLI rig into the BitFenix Phenom M, which means its a tight build. However, in order to fit both G1 970's I need a shorter power supply. My RM750 currently is too larger, and blocks the bottom GPU. For those of you who don't know, the Phenom's case is strange, as the power supply sits vertical in the from of the case, and the motherboard is upside down, with the graphics cards hanging over the PSU. My that's my problem. Your task: a modular power supply which can handle a moderately power intensive build, while still being short enough to allow enough overhead to SLI gpus. The reason it needs to be modular is because I intend to make my own custom sleeved cables to drastically improve on cable management in such a small case.
Edit: Semi-modular is accepted, though fully modular would be perfect. I'm looking for something sub 160mm if that exists.
