[SOLVED] Should I be ok with this power supply? RX 580 + XFX 850w pro
Nov 17, 2020
Hello,
Will this brand PSU be fine with the graphic card?
I'm just a bit worried because I've done my research on it and found that it's an older on.
My specs:
CPU: i7-2600
RAM: 8GB
GPU: Asus dual series RX 580 4gb
PSU: XFX 850w Pro series 80 plus bronze
Hello,
My specs:
CPU: i7-2600
RAM: 8GB
I would use it and not even think twice about it.
That is a good PSU made by Seasonic.
EDIT If you were building a brand new modern PC then it would be a good time to change it but just adding a new video card I see no harm.
Hello,
My specs:
CPU: i7-2600
RAM: 8GB
Hello,
My specs:
CPU: i7-2600
RAM: 8GB
The psu should be fine.
Take it outside and give it a few shots of air from both directions.
Blow all the dust out of it.
Clean the exhaust fan.
