Should I buy Cooler Master TC-102 and USB port problem
Jwjeremy
22
So, I was planning on doing a budget gaming pc build and came across the Thermal Master TC 102 case by cooler master at Micro Center. It was $37, and it came with a 500W PSU. I heard that the case was way too small, but I don't really need an optical drive. But the thing that concerns me is the PSU. For the money, it seemed really cheap, and I was wondering if I should get this case and if the PSU is trustworthy. I don't want it to fry and break other parts, as I am broke and only a teenager. Also, at the front of the case it has no USB 3.0 ports, as the motherboard does. Should I buy it and what should I do about the USB ports?
There should be an USB port. But if there isn't any at the front, you can use the back one but the problem comes when you try to connect external HD or other USB drives. Its hard to reach for the HD. U can get the USB extension hub and again you need to pay few extra bucks for that.
If you like it, then go for it, if it suits your need.
Good Luck :) Peace
