Should I change pc? Or parts?
Oct 25, 2018
6
Hey!
I have a Predator G6-710
And my question is if I need to upgrade or change anything.
Because I have had the computer for 2 years now.
I have a Samsung 49" chg 90 ultrawide hdr qled gaming monitor
And its Big, And I have noticed that my performance is dropping,
When I'm playing bo4
So this is ALL the thing the computer has and its 2 years old
Generally
Type PC
Form Factor of Product Tower
Location of the Nordic countries
Processor / Chip Set
CPU Intel Core i5 6th Gen. 6600/3,50 GHz
Max. turbo speed 3.5 GHz
Number of cores Four-core
Number of CPU 1
Max. CPU number 1
Key features of Intel Turbo Boost Technology 2 processor
CPU slot LGA1151 Socket
Cretch type Intel B150 Express
cache
Installed size L3 cache - 6 MB
Cache / Processor 6 MB
FRAME
Installed Size 8 GB / 64 GB (Max)
Technology DDR4 SDRAM
Effective memory speed 2400 MHz
Memory speed 2400 MHz
Form factor DIMM 288 pin
Properties Not buffered
Configuration features 1 x 8 GB
Hard disk
Type SSD - M.2 2280
Capacity 1 x 256 GB
Hard disk drive (other)
Type HDD
Interface class Serial ATA
Capacity 1 x 1 TB
Type of Interface SATA 6Gb / s
Spindle speed 7200 rpm
Controllers
Type 1 x SATA
Optical storage
Type DVD Burner - SATA
Card reader
Card reader
Flash memory card supported SD memory card
Screen
Monitor None.
graphics Controller
Type of interface PCIe x16
NVIDIA GeForce GTX 1070 graphics processor
Video memory 8 GB GDDR5 SDRAM
Video Interface DVI, HDMI, DisplayPort
Audio output
Standards Complied with EAX ADVANCED HD 5.0
Network
Wireless LAN Support Yes
Wireless NIC Intel Dual Band Wireless-AC 7265
Ethernet, Ethernet, Ethernet, Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Standards Complied with IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Expansion / Connection
Tray External 5.25 "| Internal 3.5"
Slots 1 (total) / 0 (free) x CPU | 1 (total) / 0 (free) x PCIe x16 | 2 PCIe x1 | DIMM 288 pin
Interface 6 x USB 3.0 (2 front, 4 rear) | 2 x USB 2.0 | 1 x LAN (Gigabit Ethernet) | 2 x audio / headphones (1 front, 1 at the back) | 2 x audio input / microphone (1 front 1 on the back) | 1 x audio input | 1 x DVI-D | 1 x HDMI | 3 x DisplayPort
Various
Included Accessories Wireless Antenna
Standards to be followed VCCI, BSMI, CB, CCC, FCC, RoHS, EuP
power
Device Type Power Supply
Rated voltage AC 120/230 V
Power 500 Watt
Efficiency 82% +
Power factor correction Yes (active)
Operating System / Software
Included OS Windows 10 Home 64-bit Edition
Weights and Measures
Width 18 cm
Depth 40.9 cm
Height 51 cm
Weight 5 kg
jay.wooster
621
60
Are you using any adaptive sync on that monitor ? It's a Freesync Monitor but you have an Nvidia Card ?
If i had an AMD card i would be all over that Monitor, love it.... That being said it is 32:9 which means it is essentially playing on two standard monitors at once and at 144Hz at the same time which means you need a beefy GPU to handle all that processing, a 1070 isnt going to cut it. Would be fine for a single 16:9 display at 144Hz but not a 32:9 !!!
For what i can read i would recommend the following changes;
GPU upgrade to a 1080ti or a 2080 if you can afford it (EDIT: This would be a Vega 64 for AMD)
RAM Upgrade to 16GB from the 8GB you currently have of DDR4 (get the same memory if you can)
You may need a stronger PSU than 500 Watts to run a 1080ti and on a 2080 the minimum requirement is 650W. I would suggest you need a min,. 650W for either card to be honest. CPU looks OK at 3.5 but we need details on the Motherboard mate ? Do you know brand and details ?
Oct 25, 2018
6
I have kind of a problem to find all my specs. I can't find anything about this pc. Its model number is Acer Predator G6-710
But the problem with that is, this model has more models. And I can't find this model I have ANYWHERE!
And someone knows how to find all your specs ?
The thing is....in order to find out what CPU you could possibly upgrade to....we'd need to know the motherboard.
I'm finding sites that show a similar PC with an i7....so I'm thinking it can "probably" take an i7....but we don't know for sure without the MB specs.
Oct 25, 2018
6
Manufacturer Acer
Model Predator G6-710 (U3E1)
Chipset Vendor Intel
Chipset Model Skylake
Chipset Revision 07
Southbridge Vendor Intel
Southbridge Model Z170
Southbridge Revision 31
System Temperature 25 °C
All I found when I was on Speccy, and look what my specs was
jay.wooster
621
60
It's a Z170 model. Can you download a program called "CPUID", its free, and run it and let us know the Manufacturer and Model names from the Mainboard TAB please ?
Oct 25, 2018
6
This is all the CPU-Z says about the Motherboard
Manufacturer: Acer
Model: Predator G6-710
Chipset: Intel Skylake Rev. 07
Southbridge: Intel Z170 Rev.31
LPCIO: ITE IT8732
BIOS
Brand: American Megatrends Inc.
Version: R01-A2
Date: 10/23/2015
Graphics Interface
Version: PCI-Express
Link Width: x16 Max. Supported: x16
Oct 25, 2018
6
I have also start thinking that maybe a new pc is a better option? Because I'm not a hundred if I wanna change inside the computer.
The price for all this is 2 835,96 United States Dollar. Is this a better option?
(i really love the support!)
processor:
Intel Core i7-9700K (8 cores, 8 threads)
Processor speed:
3.6 GHz (bass), 4.9 GHz (turbo)
Processor Manufacturer:
Intel®
Processor Number:
9700K
Processor Model:
Core i7
Number of processor cores:
8
Number of processor threads:
8
Cache size:
12 MB
Item number:
1311897
FRAME
RAM type:
DDR4
RAM memory:
16 GB
RAM configuration:
2 x 8 GB
Memory Expansion:
No
Memory Speed:
2666 MHz
Available RAM slots:
Number of RAM Places:
Max RAM:
32 GB
Graphics Cards
Graphics Card Manufacturer:
NVIDIA
Graphics card:
NVIDIA GeForce RTX 2080 (8GB)
Dedicated graphics memory:
8 GB
Video memory:
GDDR6
PCI version:
Express 3.0
DirectX:
12
Hard disk
Number of Hard Drives:
Total storage space:
256GB SSD + 1000GB HDD
Hard Disk Drive 1:
SSD, 256GB, M.2 via PCIe
Hard Disk 2:
HDD, 1000GB, 7200 rpm, SATA 6 Gbps
Type of hard drive 1:
SSD
Hard disk capacity 1:
256 GB
Hard disk connection 1:
M.2 via PCIe
Type of hard drive 2:
HDD
Hard disk capacity 2:
1000 GB
RPM Hard Drive 2:
7200 rpm
Hard disk connection 2:
SATA 6 Gbps
Solid State Drive / SSD:
Yes
Motherboard
chipset:
Intel® Z370
optical unit
Optical unit:
DVD Writer
Blu-ray drive:
No
Connection
Bluetooth:
Yes
Bluetooth Version:
4.2
connections:
3x DisplayPort | HDMI | USB 3.1 Type-C | 6x USB 3.1 Gen 1 | 2x USB 2.0 | Gigabit Ethernet LAN (RJ45) | 2x Combined headphone / microphone jack (3.5mm) | Microphone jack (3.5 mm)
WiFi:
Yes
Network Standard:
802.11a / b / g / n / ac (2x2)
Built-in speakers:
No
Network:
Wireless (Wi-Fi) | Gigabit Ethernet LAN (RJ45)
Sound
Sound card:
Realtek ALC233 High Definition (HD) / Dolby Atmos®
Equipment
operating System:
Card reader:
No
power supply:
450 W
VR ready:
Yes
Special Features:
85% PSU
Refrigeration:
Air cooled active
General Features
Type of product:
Stationary gaming computer
Dimensions (B / H / D):
184 mm x 440 mm x 456 mm
Series:
Legion T730-28ICO
Area of use:
Gaming, Multimedia
Color:
Black
Cover:
Tower (28L), Metal
Special Features / Design:
Full internal RGB system lighting (over 16.8 million color combinations) | Start Password | Administrator Password
Width:
184 mm
Height:
440 mm
Depth:
456 mm
Weight:
12 kg
Supplied accessories:
Lenovo USB Keyboard | Lenovo USB mouse
Manufacturer Warranty:
2 years
jay.wooster
621
60
Looks ok at a glance matey but not enough info, can you make your build on www.pcpartspicker.com and provide a link here, you will need to make your build public so we can access the link....
It if its a prebuilt can you provide a link, looks like it may be a Lenovo build ? Have you though about building yourself, it is VERY easy these days mate but understand if your hesitant...
Oct 25, 2018
6
I'm not really into building anymore. I got the feeling that, I don't wanna risk it. I want a prebuilt computer.
But the computer I sent. That information was all I found.
But is the money worth it, or can I find somewhere cheaper? (I know, building is cheaper. But it's not I directly an option for me)
