I have the following configuration
4th Gen I5
12GB ram
500 GB storage
GT 730 graphics card
I am using all three ports on the GT 730 and now need a 4 display. All displays are extended desktop, not clones
Should I add a USB to VGA or should I enable the Multi Display option in the bios so I can use both the GT 730 and the OnBoard graphics
My fourth monitor will mostly be used to show image slideshows .
thanks for you help
4th Gen I5
12GB ram
500 GB storage
thanks for you help
