Should i get a Cooler Master Hyper 212 EVO for my i7 4770k?
Oliversisu
120
Should i get the Cooler Master Hyper 212 EVO for my i7 4770k when im going to overclock? or do i need more Cooling? i also dont want it to be to expensive.
For your requirement, Evo 212 is plenty and its price effective as well. It will serve your purpose well. Don't go for any other cooler.
Okay, so how much is the Noctua? and if the Evo is good enought why do you recommend the Noctua then? Im playing games like arma 3, battlefield 4 and other games that requries a lot of CPU. So im also afraid it will begin to lagg because it gets to warm, so the Noctua or the Evo?
Desktop CPUs don't (usually) throttle when they warm up. (Laptops usually do) A CPU will typically be under 70C at full load, while it's throttle temperature is around 95C.
These bigger/better/pricier coolers are needed for higher overclocks (4.8GHz+). A 212 EVO would be great for a moderate overclock (4.0GHz+).
A Noctua NH-D14 is HUGE (google it). It will very likely be overkill unless you are going after crazy overclocks. It IS the best cooler for it's price, but it's size and weight can be an issue too.
There is no guarantee that your 4770k can reach high overclock speeds like 4.8GHz+; realistically I would expect 4.2-4.5GHz for an average chip on air cooling. I already have trouble staying at 4.2GHz on my 4670K with a Xigmatek Gaia (similar performance to the CM Hyper 212 EVO) without it going 80-90C under load in IntelBurnTest. I must have a bad chip. It's mostly luck of the draw and hoping you get a golden chip that can overclock high with low voltages.
Any air cooler with a large heat sink will do for that chip, and any all-in-one with 120mm will also be more than enough. Just go with the best balance of features and price.
I know this sounds crazy to some people who make a big fuss about 1-2 C, but all you need to do is stay under the thermal limits of your processor. The 4770k is a pretty small ship that produces less energy than high-end air coolers and 120mm+ all-in-ones can dissipate. Get something within those parameters, and you'll be good to go. 🙂
Just to give an example, my current 3930k runs Prime 95 at 4.5 Ghz all night long, and it stays in the high 60s, sometimes piquing into the low 70s. What cooler? It's a 90mm all-in-one. Why? Because I have a small case with a mATX board. You'll be fine.
Yes, it's one of the best budget coolers ever.
