Should i get a PCI wireless adaprter os is usb adequate
zakattak80
244
i have a pci card as my wireless connection, but i somehow lost the antenna while cleaning my rig and plan on getting a newer adapter. just want to know if wireless pci cards are that much better the usb adapters when it comes to internet usage including online gaming. thanks in advance
so there won't be really any lost to speeds or latency times? i kinda want to use a usb adapter since my pci card is directly under my gpu and compromises airflow.
I don't think so since it is still wireless latency, lags ant that will still struggle in some points. is you are into the gaming thing and you have the chance to have it wired just go for it ethernet cable is the best. but if you are just like me with the main downstairs and the router downstairs then you will have to stick with the damn wifi. If you go for a wifi card or usb adapter make sure is supports your router's B/G or N. N is quite good probably the best you can get.
