[SOLVED] Should I get an aftermarket CPU cooler or use stock cooling?
Fusion1005
Great
Jan 15, 2020
128
4
85
I'm planning out my first PC, and I'm debating between using the wraith stealth that comes with my Ryzen 5 3600, or getting an aftermarket cooler, like the Hyper 212. Which option should I go with?
86zx
Upstanding
Nov 1, 2019
336
67
290
8
I have a 2700x with a noctua L9 cooler which is absolutely tiny and at 4ghz is maxes out between 78-80c and it’s barely audible so a 65w tdp cpu will stay plenty cool with the stealth only reason to upgrade would be so it’s quieter
my_pc_build
Great
Nov 17, 2019
104
15
95
What KawaTom says - unless you have a problem with the Wraith, you'll get better value for money getting something else for your PC (better graphics card or whatever).
