[SOLVED] Should I go for mx150 or integrated graphics in zenbook 14"?
sathvic.p
19
I have a separate machine for gaming. I want this portable laptop, but i am concerned whether I might still need discrete graphics. Is the mx150 worth it or should i just go for the integrated graphics option?
ed: My use case is watching movies, web browsing and coding mainly.
sathvic.p
19
Depends on what you want to do on it, if you don't need anything graphically demanding at all, then you don't need a discrete GPU.
The MX150 is still low end, but significantly better than integrated 620.
