[SOLVED] Should i go with RTX 2070 3 fans or RTX 2070 2 fans?
All RTX 2070 cards have the same guts.
The only difference is the amount of factory overclock.
Two fans or three makes no difference the cooling will be appropriate to the card.
Card makers know that fancier cooling sells.
You will get fair value from an overclocked card, but I would avoid the ones with extreme overclocks.
