Should I keep the sp-120mm fans on for a front mounted radiator on the Corsair - Crystal 460x?
crispy4u
Commendable
Sep 27, 2017
21
I am going to use the Crystal 460x for my next build,and I am going to use a AIO cooler. but i'm not sure if I should switch out two of the fans. The fans on the front of the case are Corsair SP-120mm RGB fans, But should I change them out for ML140s because I want them to look good too, otherwise I wouldve gone with noctua fans but it doesn't match my scheme. Anyway, what do you guys think I should do, Im just asking because I heard SP-120s are terrible for performance
Thanks 😀 😀
Just leave the stock fans it comes with.
"...because I heard SP-120s are terrible for performance" is not enough reason to change.
People say all sorts of junk.
Install it, see what happens.
