Should I Look Into Liquid Cooling?
SIRmisterD
259
Hello,
To start off, I have my parts finalized, but I am always looking to change if necessary. Last night, I realized that my room, the place where I am going to be putting my pc, gets a little bit warm. In the winter it's fine, but it the summer or spring, it can get a bit warm. I just want to be safe and make sure I wont have any problems with cooling.
My question is, do I need to buy a Liquid CPU Cooler instead of Air Cooling?
I was looking at Corsair's Hydro series, but not sure which one to get if I need one. If I do need one, I would like it to be Corsair's.
Here is what I plan to start off with:
CPU: Intel i7-3770K 3.5GHz Quad-Core ($316.17 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Newegg)
Motherboard: Gigabyte GA-Z77X-UD3H ATX LGA1155 Motherboard ($134.98 @ Newegg)
Memory: Corsair Vengeance LP 16GB (2 x 8GB) DDR3 - 1600 Memory ($114.22 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($66.61 @ Newegg)
Storage: Samsung 830 Series 128GB 2.5" Solid State Disk ($114.99 @ Newegg)
Video Card: EVGA GeForce GTX 680 4GB Video Card ($510.10 @ Newegg)
Case: NZXT Phantom 410 (Black) ATX Mid Tower Case ($99.99 @ Newegg)
Power Supply: CORSAIR HX Series HX850 850W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply ($169.99 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($99.99 @ Newegg)
Monitor: ASUS VN247H-P 24-Inch LED-Lit Monitor ($189.00 @Amazon)
Optical Drive: AsusDRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.96 @ OutletPC)
Thermal Compound: ARCTIC MX-4 (4g) Carbon-Based Thermal Compound, Non-Electricity Conductive, Non-Capacitive ($9.99 @ Newegg)
Wireless Adapter: ASUS PCE-N15 Wireless Adapter IEEE 802.11b/g/n PCI Express 300/300Mbps Transfer/Receive Rate 64-bit WEP, 128-bit WEP, WPA2-PSK, WPA-PSK, WPS support ($26.99 @ Newegg)
Case Fans: Corsair Air Series AF120 Performance Edition 63.5 CFM 120mm ($14.99 @ Amazon)
Case Fans: Corsair Air Series AF120 Performance Edition (2-Pack) 63.5 CFM 120mm ($26.98 @ OutletPC)
TOTAL (ESTIMATE): $1,734.04
I am planning on upgrade a lot later on when I am able to, so here are the upgrades I have planned:
2) Monitor Upgrade (Buy 2 More): Asus VH236H 23.0" Monitor ($157.58 @ Newegg)
1) Graphics Card: Add a 2nd GTX 680 4GB
*** I have more, but they weren't necessary to include ***
I am planning to OC my CPU to a 4.0GHz, I know I can go higher but I want to be safe.
So if anyone could please tell me if I need a liquid cpu cooler, based on my room and parts, that would be awesome.
Thanks for any advice! :)
SIRmisterD
259
So the 212 is fine for my situation?
